I don’t recall off hand but does the spindle motor have a capacitor? If so, that could be failing which could be causing excessive startup spiking which in turn could be causing your breaker to freak out. Does this happen at all commanded speeds or can you get it going at a lower rpm?
A super dangerous experiment would be to manually get the spindle turning and then hit the button to see if that makes any difference. Maybe wrap some string around a tool holder and give it a yank, old school top style? Just don’t wrap the string around your hand or any other body parts. Also, this is super dangerous so it’s probably a really bad idea.
It’s a 3 phase motor and I don’t think has any capacitor bank as they’re not needed on small 3PH motors. What did Tormach say if taking J5 off didn’t help?
