Tormach 15L restoration
Think about adding lights to the enclosure while you have the covers off. I added some to my very early 15L and they made a world of difference for setups.
More than the already included light from tormach?
The light bar in mine was nearly useless, so I swapped in a LED waterproof floodlight off Amazon. Despite claiming some high IP number, they still get coolant inside eventually but are cheap enough to replace every few years if need be.
When i had mine apart, I considered having bed liner sprayed. That stuff is pretty tough.
Got all of the Sikaflex dried and sanded. That stuff takes 5 solid days to cure. 2k primer applied, and dried. Used the Ral 7015 for the interior chip pan. Came out super smooth. Everything was taped off perfectly. Going to apply a 2K clearcoat for the inside to protect the paint as well.
Project is coming along nicely. Waiting to see for the Black Friday cyber Monday deals if Tormach takes part. Need the turret, small gang plate and auto collet closer to install before I put on the enclosure. Hopefully there is some kind of deal or savings. Not holding my breath.
Once the machine is off the pallet, I will tackle matching the electronics cabinet and left hand side of the machine to the color scheme.
Also thinking about doing wire loom over the crusty ones I have that came with the machine. Either black or chrome. What’s your thoughts?
You mean plastic wire loom over the existing flexible conduit, or new metal flex conduit? If the e plastic make sure it’s something that won’t break down in coolant and if metal make sure the coating isn’t going to wear off your nice new paint job, do they make teflon coated flexible conduit? My 1100mx X axis flex conduit is rubbing the paint off the drip tray, but it is industrial machinery.
Quick observation. The Ral 7015 does not match the deeper grey color of the 1100MX machines. Ral 7016 much closer matches. Damn.
Also food for thought, semi gloss also does not match. Looks like I have to switch over to gloss since I am respraying.
Teflon wire loom is water, oil and chemical resistant and easily accessible on Amazon. Will be doing that instead of the polyethelene.
Two tone cabinet looks ok.
