Recently a member was unloading his 15L for $500. I saw the post and scooped it up since he was 45 minutes away from me. When I arrived, he demonstrated the machine working perfectly. He would only cut brass on it, so no coolant was ever used. The entire machine was covered in rust except the ways and screws.
I knew it would need a good amount of work, but seeing as though I don’t use a lathe at the moment, it would not detract from my daily routine. Anything that is round is use my 1100MX’s for.
To make it fully gone through and new, it needed a new spindle even though the current one was fine minus one flaw. The 5C collet threads were damaged as he bent them trying to remove the manual collet closer. Everything he turned was with a 3-jaw chuck. A new short gang plate would be needed, turret and auto collet closer. The operator console will also be updated from the one he supplied to an 1100MX version, using Rich Boreks help but I will manufacture a mounting system on the left-hand side for easier operator control. Roughly 10 grand in upgrades.
Total invested so far:
20 hours
New spindle kit from nose to pulley, odds and ends: $1300
Paint: $250
Rust remover: $100
Machine: $500
Transport/rigging: $275.
I will keep this thread up to date on the progress and chime in whenever I have a question about the machine.
I overhauled my 15L. It was an early model, not put together very well.
Had carriage surfaces paralleled, I bonded on new turcite, had that surfaced. Sent ball screws and nuts to Wedin Int’nl for rework. Also had a new X gib made. Original was more like a leaf spring. Put in new spindle bearings, which was a pain. Carriage height came within 10 thou of original height. Shimmed and aligned spindle and turret (older version).
Also, X axis stepper did not have a brake, replaced that. Much better.
Make sure lube system is getting oil to everything. Slide the x gib out and clean and inspect. Easy to do. Put a clamp across to hold the slide up against the dovetail guides.
Great idea. I actually encountered a problem yesterday with trying to remove the spindle nut. That thing is seized on there like no one’s business. Hitting it with a torch did nothing. Even with a spindle nut removing tool that locks into two of the four holes and the giant breaker bar it would not come loose. I do have the one Phillips head screw removed so there is no interference. The only thing I can think of is it is rusted to the pulley that it attaches and holds onto the spindle.
I have seen techniques in the automotive field, where they heat the threads up and use a wax crayon, and it is sworn by for being able to remove stuff and instances like this, but on the backside of that nut, who knows how badly it is seized to that pulley. I may have to make a specialized spindle pull nut removal tool that I can attach to a half inch impact driver and try and impact it off. Has anybody had any luck or techniques to remove this nut?
I have sprayed a whole can of PB blaster penetrant throughout the week onto it and it seems like it has only done half it job
Been there, done that all the time working on cars. Depending on fastener size, there is almost always a bigger impact wrench you own. 700-1000 ft-lbs and cranking up the air pressure is usually the first stage for larger stuff that’s also been factory threadlocked. Pre-spray/soaking of PB works on some but not all.
I had a couple of cases where I did have to pay someone to do it for me because some of those needed the heat of a full oxy-acetylene rig. I had luck with MAPP gas on smaller fasteners but I had to go back for the full rig for larger ones.
He would get it red hot and with the bay doors wide open, spray it with penetrating lube and that got it freed up. Nasty fumes. The wax crayon may be the correct and safer alternative. He did manage to brainlessly grab the piece hot the last time as we were chatting, so obviously, be mindful of that…
You are talking about the nut with 4 notches in it? Right up against the cast iron? Oxy acetylene and impact is probably the next step. Shove a wet rag into the spindle bore to try and keep it cooler. I think there might be set screws with brass pads to lock the nut in place somewhere in there. I’ll check tomorrow for pics.
Yeah. I removed the screw that threads into that nut. Spoke to Tormach today and since I’m replacing everything there forward we agreed a cut off wheel is the next topic of approach.
Try the punch method first. Big punch angled in one of the drive dog holes. Work your way around. I think that was how I removed mine. Belt on and tight. Gonna take some pounding. Make sure you can get a replacement part. So I found pics of my disassembly, it might help seeing everything separated. See what your working with. The big steel pipe was used to drive the new bearings on. Carefully. I did not have a press, inner race is ok to knock on. Bearing spacer is the large tube. Wash new bearings with solvent, dry, then grease. Preservative oil in the new bearings will thin the grease if you don’t. I think I did a maybe 70 percent fill. Don’t pack them tight with grease. I tightened the bearing nut pretty tight, but not gorilla tight.
Now that I’ve refreshed my memory, and taken a closer look at your pictures, I did use a punch, and a heavy hammer. Took a bit of pounding to break it loose. Pins on a spanner will probably bend or break. It should come loose.
I got around to stripping all of the rust in the chip bin. A good 24 hour so with some Ospho acid removed every bit of it. Wipe the clean and now I’m gonna take Sikaflex 291 to all of the corners inside the bottom of the pan and top of the pan to ensure that there are no pinholes in the welds for an opportunity for coolant to leak out.
Once that is done, I’ll start with the two stage primer. Tested out the paint on the outside from cross-link paints, and I chose glossy. Not too much a fan of it because it doesn’t match the finish on the 1100s so I ordered up a bunch of semi gloss instead.
My plan for the paint scheme is to make it identical to the way the 1100s look so most likely the entire outside will have the darker gray and the inside of the enclosure will have the lighter gray. The spindle carriage and bed weighs will also have the lighter gray so not much lighter gray on this application but enough just to make it match my 1100s.
That is the residue that is left after the Ospho dries. I scraped it off, scour padded the unit, neutralized, let it dry and applied the Sikaflex yesterday. Every corner was addressed, and a thin layer applied for extension.
Roughly 5-7 days is needed for it to fully cure with respect to my humidity and 68 degree temps and I will then sand the flat areas for an even base before the primer.
One thing to know is I own the company MFC MD, and one of the products we made is the Clearview windows. It is a solid half inch polycarbonate that is ceramic coated on the inside to reduce sandblasting from chips, but most importantly allows, the coolant to drip off a cleanly and being able to view the parts so that is one of the first upgrades that I’m gonna do once I get the enclosure ready for paint.
