Here’s the E-stop video from it: https://youtu.be/SD_VSWS2jmA
Regarding the oiler from my previous post, I did fix the leak and I assumed oil was properly distributed since there was some oil on the tool collet after completing spindle warmup. In hindsight running a regular program before fully inspecting all the oil outlets was probably a really bad idea, but the spindle and all axis worked fine so I thought it would be okay (clearly it was not)
So when the machine started ramping, before the tool even started cutting anything, there was a large Boom sound so I stopped it. My friend says he saw like a plume of dust coming off the top of the machine at the moment of the boom. Before the boom happened, I noticed a very faint rhythmic sound similar to this (this is a knife sharpening sound i ripped off of youtube): https://drive.google.com/file/d/1o9S7lbJRVsJJO1C37BmFIUp4ss6xr249/view?usp=sharing. I remarked “what’s that sound” right before the crash(?) and while the words were coming out of my mouth is when the crash happened. I don’t know when the E stop occurs in the video but I assume it happens the moment the video ends since usually E-stopping would make the status tab turn yellow, so there’s a chance the boom happened while I was on feed hold, but I am unsure. I have no idea where either sounds came from or why it happened since nothing was touching. Additionally, movement in All axis seems completely fine both before and after when jogging. Ive jogged Z a lot further than where the video shows, and spindle warmup was ran before the program. Also, the spindle works completely fine after as well.
After checking everything and not being able to find anything, I reran the program until before it started ramping. Once the ramping began, I heard the strange rhythmic sound again and stopped the program since I was scared it would happen again.
Originally we thought it was the hinges of the spindle access door bending the acrylic sheet downward until it launched back upwards to create the noise, but the 1st hinge must’ve been cleared already due to how low I was on the Z axis already. Any idea what the sound may have been?
