MicroArc 4 Connector Experiments
Earlier this year I purchased a 770MX. This mill controls the MicroArc 4 with an EtherCAT MX 3660 driver. When I received the mill, the MicroArc 4 would not properly execute G0 Axxx commands. For example, when a G0 A90 command was executed, the MicroArc would move between 5 and 30 degrees, stop moving, and would generate a binding noise. I reached out to Tormach support and they sent me replacement pins for the MicroArc connector. I replaced the pins and unfortunately, the problem remained. Tormach support diligently attempted to resolve my issue, but unfortunately, they were not successful. Thus, I began the following experiments in an attempt to resolve my issue.
Using an IR thermometer, I determined that the housing temperature of the MicroArc 4 connector was 139 F, which was 69 F above room temperature when the MicroArc was static for at least 8 hours. When I inquired with Tormach support about the connector temperature, they responded “Regarding temperature, I’m not sure if 139 F is above normal as these do run a little warm mostly due to the motor holding it’s position while sitting idle.”
Based upon advice that I found on the Tormach forum, I applied conductive grease to the pins in the MicroArc connector. Again, using an IR thermometer, I determined that the housing temperature of the MicroArc connector was 96 F, which was 26 F above room temperature when the MicroArc was static for at least 8 hours. Thus, the conductive grease reduced the connector housing temperature increase by 43 F (from 69 F to 26 F). After applying the conductive grease, the MicroArc properly executed G0 Axxx commands most of the time. However, the MicroArc did fail to execute G0 Axxx commands occasionally. Thus, I did not find that conductive grease was a reliable solution to my issue.
Next, I tried replacing the MicroArc connector pins and sockets with gold-plated pins (Digikey A25123-ND) and sockets (Digikey A251243-ND). Again, using my IR thermometer, I determined that the temperature increase of the connector housing was only 2 degrees when the MicroArc was static for 24 hours. Importantly, after installing the gold-plated pins and sockets, the MicroArc has always properly executed G0 Axxx commands.
A photograph of the gold-plated pins and sockets (far left), unused Tormach-supplied pins and sockets (middle left), and used Tormach-supplied pins and sockets (far right) follows.
One can see that the plastic wire insulators the right have discolored due to heat. In addition, one can see oxidation on the pins and sockets on the right. It may be that this oxidation is causing an increase in resistance which generates heat at the pin/socket interface.
While there may indeed be something unique with my mill that has caused the above-described issue, I wanted to pass along the results of my experiments on the MicroArc connector in case anyone else had similar issues. To summarize, replacing the original Tormach pins and sockets with gold-plated pins and sockets resolved my MicroArc 4 issue.
Hoyt
I suppose I can’t say I’ve ever had my MicroArc powered for that long continuously, but it does seem like maybe there’s something else going on. It definitely seems like there’s some excessive current draw happening there.
Now that you have the gold plated connectors, it might be worth looking for that. Thing is, excessive draw leads to heat, heat leads to corrosion, corrosion causes resistance, resistance leads to heat, etc. Once that loops starts, finding the actual problem becomes increasingly difficult. Connectors will always be the weak point in this scenario as they naturally have more resistance across the terminals than wires and such so that’s going to be an obvious failure point very quickly. But if the root cause hasn’t been found, there’s a good chance of further problems down the line.
Just measured mine (it’s been on for 6 hours) and the plastic housings 124f. I have never unplugged it since the day it was installed.
Mines a 2021 1100mx.
Ian,
 I specifically chose gold-plated connectors because they do not corrode or
oxidize.   I wanted to remove the oxidation variable from the issue.
  It would be great if Tormach would determine the root cause of this issue.
Harold,
  Your connector is quite warm also.  Glad that you are not having issues.
In case others on the forum have issues similar to mine and do not desire
to swap pins/sockets, a software alternative, which I am still using as I do
not have complete confidence in my MicroArc, is to replace all G0 Axxx
commands with G0 Axxx F1000 commands.  Such a replacement slows
down the rotational velocity of the MicroArc, and at least for my MicroArc,
eliminates the binding issue.  I used Grok Build to create an application
that rapidly performs the G0-to-G1 replacement in my .nc files.
Hoyt
No need to burn tokens to create a program for anyone else who wants to do the same thing. Use the scripting/command prompts already in your OS.
Linux/MacOS
find /path/to/dir -type f -name '*.nc' -exec sed -i -E 's/^(G0 A-?[0-9]+(\.[0-9]+)?)$/\1 F1000/' {} +
Windows Powershell
Get-ChildItem "C:\path\to\dir" -Recurse -File -Filter *.nc | ForEach-Object {
    $p=$_.FullName
    $s=[IO.File]::ReadAllText($p)
    $s=[regex]::Replace($s,'(?m)^(G0 A-?\d+(\.\d+)?)$', '$1 F1000')
    [IO.File]::WriteAllText($p,$s)
Having worked with much higher amperages for a number of years (like in the range of 200A DC) poor conductor or joint choices that result in warm wires outside of their specifications are a problem at any amperage in terms of having normal performance. An electrical engineer type would need to look at the specs and figure out what sort of resistance increase you have if the wires are that warm and if that temperature is in the specs of the particular wires used for that conduction path where it would impact the performance/accuracy of the signals carried…etc…etc…
Absent all the analysis, if it was a 1:1 fix where that one change dropped temperature and that allowed you to consistently execute the GC as written, it seems like a simple upgrade worth undertaking without doing all the detective work.
Good detective work, even it was something that was just your machine!
Great work and info Hoyt!
Nicely done
Ed
I am sorry to report, that while my MicroArc connector remains within 2 degrees of ambient temperature, my MicroArc just failed to properly implement a G0 Axxx command. The specific failed command was a G0 A45 command. My MicroArc. moved about 10 degrees, made a binding sound, and then stopped moving. (As I was monitoring the machine, I did not damage my part.)
As a result, I will rely on software to translate G0 Axxx commands to G1 Axxx F1000 commands.
Another long-term alternative that I am considering is adjusting the maximum rotation speed in PathPilot.
Hoyt
(post deleted by author)
