We’re using XS Tech Pro’s in an educational space with wiggler edge finders.
The lowest spindle speed of the XS Tech Pro is 3500 RPM. Our wigglers don’t love that, as they typically have a 1200RPM or 1500RPM “max,” and while they still are working okay, we’re losing them at a surprising rate.
I’d love to know if there’s a way we can get the low-end of the spindle lower, even if it’s far beyond the usable torque range of the motor.
I think that’s a BLDC motor on those so a bit tricky to control speed ‘aftermarket’, but maybe there’s a way.
Any reason not to use one that doesn’t need to be spun like some of the electronic/LED edgefinders? I vaguely remember running across one with a small shank although forgot where.
I have a standard xsTech and a probe is what I’d rather have but I can understand wanting to teach students with the wiggler.
It depends upon the hardware running the spindle motor. It may not be able to sustain a lower RPM than the machine has already been configured for. If it can, you would have to edit a couple of lines in the machine definition file and keep up with the edits between PathPilot updates (been there, still doing that on another machine).
