Failed to bring Machine out of Estop
I’m having trouble with my 770M. Just purchased the machine used everything worked prior to tear down and moving. I cannot get it out of estop, limit switches check ok, replaced the communications cable ? Any help would be appreciated.
The Ethernet cable isn’t for internet. It’s the controller cable.
Was that it? Do I win the prize?
Describe your procedure for starting up the machine.
What is the specific error message you’re getting?
(FAILED TO BRING MACHINE OUT OF E STOP) That is what comes up on the screen.
Exactly when does that come up? What order do you power things on and switch switches?
comes up as soon as you hit the RESET tab on the path pilot screen
What order do you power things on and switch switches? The mechanical ones. It might not matter and it might matter a lot. Without context all we can do is guess and people rapidly get tired of playing 20-questions just to try and help.
Main power disconnect, 2 path Pilot. lower screen says hit reset button. that’s when the code comes up. I have tried to reset the estops before during and after still come up with the same results
I know it’s the stupid question but are you twisting the big red e-stop to reset it.
thank you for the help, suggestions and sarcasm. The problem wound up being a chaffed wire in the conduit. WATCH WERE YOUR SWARF GOES!
