Hi, i am wondering if any one has come across a problem like this,1100MX
I was about to run the spindle warm up program when an alarm appeared Spindle: Encoder RPM feedback abnormally low.
Now when i fore a S10000 M3 the spindle winds up to RPM but on the controller it isnt reading the correct RPM. it last a few seconds before alarming out.
Now i tried to send the tool back to atc where the same alarm appeared a the M19 wasn’t in the correct position.
Any suggestions or thigs i should check before buying parts
I don’t have a tool changer so you might want to wait for the next reply but.
It’s probably the vfd side. I don’t think the encoder reads spindle speed during normal operation (only taping and ATC alignment) when you hit start the command is sent to the VFD and the VFD sends back the check that it has reached speed.
You might need to unplug disable the ATC to get the machine to identify if the problem is on the mill or ATC side.
Things to check on encoder. I don’t have a ATC but I have had encoder issues. Run the admin_encoder_test first. If that passes it’s definetly not the encoder. If fail Check to see if the magnet is still in the encoder, the gap between reader and magnet, and make sure there isnt magnetic particles stuck in the magnet hole. Might also check that the pulley and belt are tight as slipingbelt or pulley will effect alignment and encoder.
You should open a ticket though.
thanks for responding. i have disconnected the atc and run the encoder test. the test indicated the belt was on the low position (on the high pulley with high gear selected) . i repeated the test for the same message to appear. said to contact tech support.
Just want to properly diagnose which part has failed so i can order another one,
First remove all accessories and retry-- ATC, toolsetters, probes, maybe even disconnect the lights and other nearby machinery just to eliminate other possibilities. I had a toolsetter go bad and cause spindle speed errors like that in my 1100mx (which I didn’t figure out until I’d re-adjusted the spindle sensor, bleh). It appears the speed sensor is very susceptible to electrical noise.
I don’t know why they wouldn’t use the spindle sensor for RPM all the time if they have it.
Simple things first, have you tried resetting (physically) the encoder pickup? It should be roughly one sheet of paper away from the spindle. It’s possible that vibration over time has wiggled it out of position. While you’re in there, clean out any chips or other debris that might be on the encoder pickup or the spindle. Once that’s done, test again and see what happens.
Thanks for your response. I changed the config to a m+ as it does use the encoder. i was able to start the spindle up to 5000rpm. after changing the config back to MX i could no longer get the spindle to go past 46rpm which caused the abnormal alarm. i think by doing so this has proved that either the encoder or ring has failed,
The M+ configuration still has the TTS spindle which does not use an encoder. Maybe that’s what you meant and that was just a typo?
In either case, you’ve proven the encoder signal is an issue, but not that any particular thing has failed. I would still check the spacing and make sure there is no debris anywhere near the encoder. Then check that the encoder connections on the controller side are good as well as look for any pinching or damage to the wires, especially in the head around the motor and such.
I looked at my encoder spacing a while back and noticed that the trigger ring is not exactly concentric with the spindle. Makes setting the gap at the ferrous pin difficult.
It’s gotta be close horizontally .3mm I think. The vertical range is like 6mm I think. But sometimes the magnet flies out of the hole. What I did was press blue tack in the hole to clean out all the steel filings that get pulled into the top of the hole. Because the magnet isnt flush with the top of the ring. The reader is $150 at least last time I looked. I also clean the reader while I had it off. It’s really godly because you can’t test it unless everything is reassembled. There’s no way to check the signal on the reader that I know of.
Meant to say after changing config. from MX to M+ i learnt that the encoder was the problem. After cleaning all surfaces and rechecking the gap, making sure wires weren’t pinched or loose. The issues still came back to encoder fault
So before i bolted the new encoder and ring, i thought id try a simple s1500 m3 command. it worked no alarm. So i thought great back to business. I begun running the warm up cycle got near the end as it got to 10,000 rpm and the alarm came back. So i installed the new encoder and ring only to get the same alarm after the encoder test. i am lost now.
There has to be a way to measure the encoder signal with a meter or a status light but I havnt been able to find it yet.
I’m guessing your tormach ticket was waiting for the part to proceed and since it’s Saturday you have to wait until Monday.
All I can say is check the height of the reader because they aren’t all the same height. I had to shim my readers height 1/4 in to get it to line up when I replaced the spindle on my 1100mx. And .3mm space between the reader and magnet.
You could try checking for continuity on the old reader. I can’t see the wires on mine so I don’t know if it’s just a magnetic switch or more complicated dual position switch. Or wait until Monday. But you shouldn’t need the encoder to run normally. My encoder was out for a couple months and I don’t know until I tried to run a taping cycle. But I don’t have a tool changer. If you’re desperate to run you could unplug the tool changer and it should work. I think.
its funny you say about the height. when i unbolted the old encoder i saw a piece of stainless steel shim under it. i have tried using it and trying with out. only to get the same results. i was told the gap was to be 0.1mm. ill try with the shim to lift the height with a 0.3mm gap.
Since leaving it on for several hours. i tried a M3 command to find i know how a new problems. Error 1 on the VFD. spindle stills turns freely by hand
And you have tried unplugging /disable the tool changer?
I’d check all the connections in the power box. Just unplug it and check every electric screw (careful, obviously electricity) the vfd is super sensitive to loose connections as it monitors magnetic induction thousands of times a second. that doesn’t fix it it could be a wire. Send a couple photos of the machine. I’d check the wire looms in the energy column “out the top” check where the metal looms bolt through the frame, if the nut on on the threaded part works loose and the threaded part backs through the hole all the strain is on the wires and the wires are riding on iron and iron will wear a hole in anything. Also if you have the metal wire sheath that goes down somewhere inside the enclosure it inevitably gets metal shavings and coolant in there and eventually it cuts into the wires inside. That should take most of Sunday which will fix your problem or shorten your discussion with tormach on Monday. Your not running a welder near there, if you are unplugging that too.
Yeah, make sure you’ve eliminated all possible sources of electrical “noise”. I mentioned earlier getting frustrating spindle-orient errors that were caused by plugging in a cheap electronic toolsetter.
